I was engraving this 15" round sign (“Fill only” no lines) with my brand new 50W Co2 Laser I got just 2 days ago. I was cutting via USB / RUIDA 664XG with Lightburn on my new windows 10 laptop @ 200.00 speed / 20.00 power.
2/3 of the way into the project the laser started to follow a wavy type of line and this occurred all the way across the image. The piece being cut was secured in place firmly so it had not moved and the surface is perfectly flat. Shading and lines don’t match up either if I run them as “line/fill”
The Laser is 2 days old, the Gantry is solid, belts are tight, mirrors are alligned and not loose and there is no debris in the bearings, pulleys, belts etc…
Here are images of the cuts as well as what the files look like for comparison.
Even though the previous 2/3 of the 15 inch diameter project had no issues at all? a loose Optic or mirror would rattle all the time. This is on the Y axis as well so Maybe a Gantry Stepper Motor? Again, it is zone specific. It did this in the same exact spot the second time I ran the project.
