Hello everyone, in version 1.5.06 is there any way to save the position of the tabs and toolbar? To make things easier, I use macros that need the exact position of some toolbars, thank you all
Can you provide details, or something to illustrate what you mean? When I close Lightburn, everything is in the same place when I open it. This is true even if I open a New Window with a copy already open.
Read this doc:
Hello everyone, in Lightburn if I move a toolbox to another place it will remain there, but my question is how to save the position of these toolboxes if I have accidentally moved a toolbox to another place, in the Window menu there is only the option to restore the factory default, not the default I had left
Not sure if this would work, but you could load a preferences file from before you moved the window. This MIGHT reset it’s location, but it will also reset any other changes you’ve made since.
