I’m trying to jog either X or Y axis in the Move window and nothing happens. If I enter the code to move the X or Y axis in the console window it works fine. I tried changing jog option from “continuous” to step with not positive result.
I’m using the latest LBDEV file from Wecreat, and using Lightburn 2.1.04.
Also, when I connect Lightburn to the Wecreat device I get a message in the console stating the following “Your laser has been detected as a Wecreat device but you are not using a custom gcode device with the Wecreat device flavor”.
The CORE version is the GCode license version. The PRO version is needed for Ruida’s and Fiber machines. The Pro license works on GCode machines as well as the others.
Okay, I realized after a bit of poking around that Lightburn will import ZIP files as well as LBDEV files.
But, when I try to import this ZIP file it does not display in the devices window as a configuration file.
I have another “Home” computer that I also have a copy of Lightburn installed, not connected to any Laser" and I can import this lbzip file into Lightburn, the only difference between the 2 is my home computer is running version 2.1.02 and my shop is running 2.1.04.
I hope all of this makes sense. This is frustrating to say the least but I do appreciate all the support…
