So when I realized what that M14S0 command did after running once, I took it back out. It ran great until I went back into MakeIt! to do a comparison on speed and quality. When I came back to Lightburn it’s not working again. lol
Was nice while it lasted … I’m going to tinker around and see if that M14S0 command run once will speed it back up.
EDIT: No luck, I repeated the process and it’s running slow and jerky again.
That’s what it looked like before I started tinkering. Adding M14S0 to the beginning and toggling Use G0 moves for overscan and Emit S Value with every G1 command to on is what I did.
It ran like a banshee until I went back into Makeit! to run a comparison test. When I came back to Lightburn it was slow and jerky again. I repeated the process and it didn’t speed it back up again, so I’m right back where I started only with more questions. lol
Yeah, that’s why when I ran the first job and realized the fan wasn’t running I went and took that line out. It continued to run great without that command in until I exited Lightburn and started Makeit and came back to Lightburn.
Which is pretty much what happened the first time I had it working. I’m guessing Makeit must load some settings or write to the laser when it loads that breaks Lightburn? Even unplugging the laser and turned on the power switch to clear the capacitors doesn’t reset it. So maybe it’s just something weird and I’m coming to wrong conclusions…
Look forward to seeing what comes from testing. Thanks!
