I have been able to install LightBurn on my MacBook Pro running Monterey and use the controller download to help the software discover my WeCreat Vision laser. The WeCreat worked for a few small test projects and then stopped framing projects correctly. When given the frame command the laser moves in a very small square at the Home position (upper left corner). Also, I get a message that says the Laser is BUSY at 99% done and just sits and never completes the command. I have the most current versions of the controller file as well as the software. I have trouble shot the issue by installing LightBurn on a PC computer running Windows 10 and I got the same result. Has anyone else seen this type of problem and how did you go about correcting?
