Hi all,
Just installed a new Reci 90watt W2 tube with matching 100 watt cloudray laser power supply. Also upgraded to Ruida RDC64432G controller.
I’m getting these weird fade outs that are consistent across shapes no matter the size. Not sure what to change on the settings or if it’s a faulty power supply. Was running smoothie ware with Cohesion3d mini and had the same issue, hence the new ruida controller.
Nor sure if it’s hardware related, wiring related, my settings or what. The first two I’ve checked and seem fine. Perhaps I have minimum power settings or something set wrong?
Wisdom appreciated! I need this thing back up and running
