Hello All, I having a problem trying to weld a drawing together. I have attached 3 screenshots. Welds most but not all.
What am I doing wrong?? Help
It is difficult to see what you want to achieve. But a typical problem is that the parts do not touch each other. Try zooming all the way in at the edges and see if that’s the problem.
Thanks for the reply. I’ll check that.
Another way is to double the length of the pieces you want to weld, Then they will snap to center line and not worry if they are touching. Group the three and select pieces and use boolean assistant.
Thanks for the tip
