Hello, i’m new at this software and have run into a small problem. The maze in attached image is created using only rectangles. When i use Tools/Weld shapes it does that except in two places, marked red in image. Is there any other way to remove this lines.
Regards, Tass
Chances are that they were very, very close, but not quite touching. The simplest way to remove them would be to draw a rectangle that overlaps them both and weld it all. You could also use the Node Edit feature to remove the extra lines.
