Is there a way to weld/join/delete overlapping image parts in Lightburn itself? This is the same image, not two overlapping images. I am trying to connect the steam to run LEDs behind them. Thank you…
Just use node editing.
Thank you Dskall. I did not realize that function allowed deleting lines. Works great.
Most powerful feature in Lightburn.
Brainlock…
A) It turned out very nicely…Thanks again.
B)It seems to be in node mode and not a complete graphic. When I use “Select” it will not select the entire graphic, but the nodes. How do I join it back together as one graphic in lieu of modes? (The “group” will not work.)
If above doesn’t wok maybe post your file to see what you are having trouble with.
Thank you both…Here is what I found…The “Auto-join” would not engage. I kept thinking it was a group-ungroup thing, so though the people images were not highlighted, I could group and ungroup in the pull down: for whatever reason. Now I have successfully used the nodes and have returned it to a Lightburn traced image. All is good. After I replace my laser’s tube, I will cut out and paste…If I like it. Awesome input…Thank you.
