What camera model is recommended for a 600 x 600 mm working area
Hi,
I am using Sculpfun S30 Ultra 33W which has a 600 x 600 working area.
Now I a struggling with finding the correct camera module which is compatible with lightburn (core-license) and supports a 600 x 600 working area.
my last try was a 8MP 4K camera with a 120° angle, a so-called lightburn camera. But when I select it for calibration, Lightburn crashes immediately without any notice.
Can anyone tell about a camera supporting the needed working area which is compatible to Lightburn?
In the documentation, under tools and features, you will find a camera section with a tool that helps you find the right camera.
Try the new relase Lighburn 2,there’s some new features with camera.
You can choose any cam that is recognized as webcam by the control PC. I suggest using as much resolution as possible. Also, try to avoid wide angle, so you need quite some height for that workspace.
Personally, I use the Sculpfun CAM500 also with the Ultra, but only for a 400x400 portion of the workspace. Since the camera usually only makes sense for smaller pieces, that’s no issue.
Hi, thanks for the tip, the 2.0 release candidate worked like a charm with my camera. Positioning after calibration is perfect
To choose a camera, you will need to measure a few things on your laser. Our Camera Selection Helper can help you select the correct camera based on these measurements.
