What gets measured in Millmage does not product same measurements carved
what I put into MillMage on screen in mm is not the same when I carve it on the wood, seems what gets carved is smaller than what MillMage has for measurements anyone know how to fix this?
Is this a new machine?
Have you checked the calibration of your steps?
how much smaller ? are we talking 1mm or 10 mm
we need more context to be able to help
can you upload screen shoots photos , mage file so other can look at it
Draw a square 100mm side with a Profile cut by the outside 2mm deep, run the job and measure the output.
We need more information. For example, if what you are carving is a ‘Profile’ operation, and you tell the operation to cut Along the line, then the shape will be smaller than the outline by the diameter of the cutting tool.
If you tell MillMage to cut Outside the line, then the resulting cutout would be the same as the source shape.
That’s all assuming that your machine is properly set up, and telling it to jog 100mm actually makes it jog 100mm.
this is what I am referring to. I put in the actual project measurements and I set up everything according to where it needs to carve it and it doesn’t come out where I had it based on the layout.
Can you confirm that board is 800mm long?
yes it is 800mm long, but I think I fixed the issue, when I upgraded my Genmitsu 4030 v1Pro to 1010 it increased the size but I forgot to also update the Gcode settings on the machine, as after I got it build with the bigger tracks we ended up moving so in the madness of that and not being able to set it up at the new place it didnt get it, now that I have my own workshop with it setup I updated the 130&131 settings and it works as expected no issues.
