What if material catches fire?
Pay attention during the first Material Test and you’ll do fine.
Show pix of your results so we can look over your shoulder!
To a good first approximation, everything a 10 W visible laser will handle is flammable. It’ll get some traction on TiO₂, but the results taper off pretty quickly after that.
This in 1/16 basswood, a hexagonal shed (parts for peaked roof to the right).
I knew in advance I’d need to sand the edges to match the angles, so this was as much learning how to do a slightly tricky design in Lightroom as it was to actually cut something on the S-1 10w. Not visible are the hexagonal floor and ceiling pieces. I’ll probably cover this with some form of HO scale shingles. It’s about a 1" cube in size (for those of you who don’t think in 1/87 scale…)
One small design problem was getting the hexagonal floor/ceiling to the right size. I wonder if there’d be any demand for an option in Lightburn to create a regular polygon where you set the length of one side, as opposed to the current bounding box. (Yeah, you can do the math to go from ‘given side x N sides’ to ‘bounding box’, but it would be convenient to have the computer do it for you…)
Do you have Air Assist? It makes a big difference with faster cuts and less flareup.
It would be a good addition to the Shapes Properties Window
Yes, I do have air assist. It’s currently on Auto, but maybe I should set it to Max for the test cuts.
(Today I moved the laser from the garage to its permanent home in the basement. And I got a shipment of interesting stuff to cut, mostly Laserboard and some really thin MDF.)
Nice setup. When cutting, max air is the best. When engraving, just enough air to keep the nozzle pressurized is needed to keep the lens clean.
I see the ducting for the exhaust, so that is good. Does your cabinet have air inlet holes?
Actually, the ducting behind the styrofoam is for the airbrush booth on the other side of the wall. For the laser, I have a air filter system.
Maybe you can mention what it is. Most discussed in the Forum typically yield poor results, based either on smoke removed or lifetime of the filter before maintenance.
My iCube came with paper + charcoal filters. About 3 small projects was all it could handle before smoking up the room.
I vent through a bedroom window. 3" duct for the 10w and 4" for the 40w, both have inline fans.
My filter is this Creality unit, which I got on sale Amazon.com: Creality Falcon AP1 Mini Smoke Purifier for A1 series Laser Engraver, 174m³/h High Airflow, HEPA & Activated Carbon Filter, 99.9% Smoke & Odor Removal, Quiet 56dB, Compact Desktop Fume Extractor : Home & Kitchen (I ordered a Creality laser, but there was a problem with the laser so I returned that.) The one problem with this unit is that Creality doesn’t currently list replacement filters for it. Seems to work OK.
It’s set up to do auto-on with Creality lasers, so I have to remember to turn it on and off.
I predict they never will, so you must put on your engineering hat to figure out the least-awful aftermarket filter hack.
An extensive discussion with some pointers to some replacements for some filter boxes:
The reason I returned the Creality laser (the fan wasn’t working), rather than trying to get a fix, was that I just didn’t have confidence in their support. Selling a purifier without also having the filters in stock is part of that “loss of confidence”. I thought the laser itself was a well designed product, although it required a lot more assembly than the XTool S1. The purifier and laser would talk via WiFi, that’s a nice feature, so the purifier would turn itself on when the laser was working.
Man, the things they’ll do to avoid a wire … :grin:
Actually, it’s so they can make everything controlled by an App (iPad would probably be a reasonable controller…)
You any good with a soldering pencil? You can use the Air Assist output to control the filter fan.
What are you proposing? Create a USB-C cable that can trigger a relay to activate the filter? The problem with that is the filter powers up to an OFF state, and requires a long-press of the button to turn it on.
That suggests a more complex project than you might want to get into. It can be done, but I was not thinking USB. Does it have a USB input at the filter, curious that you mentioned it?
No. There’s a power connector, and 2 buttons on the front. One on/off, the other controls fan speed.
Do you know an Electronics Technician or Radio Amateur that can help you? This is not something that can be easily tackled by remote.
Not worth it. I will make a ‘preflight checklist’ that includes “turn on the filter” and “set the Z height/focus the laser” :grinning_face: And a postflight checklist to turn the filter back off.
This is one of the best compilations I’ve found of diode laser settings, including a discussion of fire risk for each material: Diode Laser Settings Database — xTool, Sculpfun, Ortur (5W–40W) — Laser Tinkerer
