I have hard time choosing the right size of mirrors for my DIY CO2 130w laser.
Working are is 1500mm x 1000mm.
Right now I’m thinking about getting 30mm diameter mirrors.
Should I go with bigger mirrors?
Maybe 25mm is fine as well?
Should I buy laser head with water cooled lens?
This is all new for me and I can’t find much informations about this.
Thanks in advance for all answers and time.
If you use your laser for “normal” purposes, a lens (and the mirrors) rated for at least 130 Watts is good enough. Water cooling of laser heads I have only seen on metalworking lasers and other industrial special lasers.
I could not see the specification that their lenses can handle 130 Watts. It’s possible I missed it.
If you see Cloudray’s products, it is clearly stated which Watt strength they are rated for.
