Tip and Trick: “Pass-Through” Mode
The “Pass-Through” mode in LightBurn is great for those who pre-process their images in external software (like Photoshop) and want to preserve the exact dot pattern in their engravings. When you enable “Pass-Through,” LightBurn bypasses its internal image processing, using your image data directly, which preserves detail and can speed up processing time.
How to Use It:
- Import your image into LightBurn.
- Select the image.
- In the ‘Cut Settings Editor’, find and check the ‘Pass-Through’ option.
This feature ensures the laser engraver outputs the image exactly as intended, perfect for detailed and photo-realistic engravings.
