I’m sure it’s a simple fix, but I haven’t discovered it yet.
Let’s say I have a logo that is a circle, or not. The way my laser is setup for my rotary, I have to rotate my image -90 degrees. When I do, it get’s messed with. The proportion is off. Is there a way in LB to stop that, or do I just have to resize it while looking at it sideways…
The four rotate handles allow you to rotate the object freely using the mouse. While rotating, the relative rotation is displayed in the status bar. Holding the Ctrl key (Command on Mac) snaps the rotation to the nearest 5 degrees, holding Shift will snap to 15 degrees, and holding Ctrl+Shift snaps to 45 degrees.
I use ^shift anytime I need to change something and keep it square…
That whole page of documentation (and the rest) can be enlightening.
