When trying to frame, laser goes back to home
Falcon 2 40w
When framing my laser will go back to home and frame from there, not from where i want it to frame.
I am new to this.
I have only done a couple burns, the material tests and creality file they send and one project.
At first when framing she would go to the right as far as she could , now it’s doing this…
When i load light burn Auto connection is only connection in dropdown, i have to readd lassr to get com 4.
Post a screenshot of your entire Lightburn screen with the laser panel showing.
Did you created your laser device by importing a .lbdev file? Just drag the file over the LightBurn workspace to auto-import.
https://wiki.creality.com/en/laser-engraver/creality-falcon2-series-troubleshooting/lightburn-software-compatibility-machine-tutorial
Additionally read the following docs:
I followed the instructions that Creality sent me, i downloaded 2 files and put on the card and done it themat way.
One was for the laser and one for the bed, sorry i am very new to lasers.
The laser did work perfectly i did a couple material tests and and 2 projects.
I will do thatas soon as i get home from work today.
Here the setting screenshot.
Since you’re using user origin, you need to set the origin point. Using the move arrows, place the laser where you want the origin point to be and click the set origin button. It should now frame from that point.
What did i do before and it worked.
I will yry that and let you know.
Also select Use Selection Origin
Yes that worked.
Thank you so so much :blush:
Having a different issue this time, she will go to home no problem, when i press go to origin, she will go to just outside project.
Did you read the Coordinates and Job Origin doc?
Where did you set your origin?
I never pressed set origin😳
Well, that could cause issues.
Goes to origin :smile_cat:
Yep, i will remember everything eventually i gurss.
Just so much to remember…
What is a good score setting on falcon 2 40w, 3mm bass wood, ease.
Creality WIKI:
Thank you.
