When using LightBurn, the laser also makes marks on the dislocation Lines.
boa tarde , tenho um lazer atomstack a5 laser e ao usar o vosso programa o laser marca tambem nas linhas de deslocamento, ha alguma forma de retirar isso?
Good afternoon, I have a laser atomstack a5 laser and when using your program the laser also marks the displacement lines, is there any way to remove this?
Hi, try with enabling laser mode setting (#32), go to edit and then edit machine settings.
If the engraver was designed for a spinning motor, a Machine Setting for $32=0 will be seen. This allows the motor to keep spinning as the head of the engraver moves. For a Laser, to enter Laser Mode, you set $32=1 to turn the laser fully-off between engraved lines.
Also, turn off Constant Power and be sure speed is set in mm / minute. A 10W engraver is quite slow.
If you would like further clarification, please share a Screenshot and your Machine Settings in a reply below.
Machine Settings:
In the Console window in LightBurn please Type the following:
Then press Enter.
Select and copy the codes from the Console Window in LightBurn and paste them into a reply here. You can scroll the message in the Console window and capture all the codes from $$.
In an hour I’ll be able to show you the leisure settings
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=1
$32=1
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=1
$32=0
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
<Idle|MPos:-32.332,3.012,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Fluxo inicial
Layer C00
Trabalho interrompido
Fluxo concluído em 0:07
ok
ALARM:3
Reinicie enquanto estiver em movimento. Grbl não pode garantir posição. É provável que haja etapas perdidas. O re-homing é altamente recomendado.
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=1
$32=0
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
The fastest way for me to see what is happening is to invite you to click File, click Save GCode and upload that file here.
This will show me how the laser has been set up in LightBurn and should show me which changes are needed.
The machine settings ($$ codes) you showed me look fine.
