I need to open the GRBL configuration for Lasergrbl to change the value of $131 to 380. How do I do this?
You can change GRBL configurations in either Edit->Machine Settings or by directly inputting commands into Console window.
You will have to forgive my ignorance as I’m an old bugger. I can’t see how to change the $ value in the machine settings, and I don’t understand directly inputting commands into Console window.
Ok Mikey I’ve done that, what do I click on next to finalize it ?
Press the enter key? Not sure what you are asking. $131 is the Y-axis maximum travel parameter. I presume you are changing it because you added an extension kit, right? As long as you have made any needed adjustments for wiring lengths, you should be ready to go.
Thanks very much again Mikey, felt a bit stupid about hitting the Enter Key. All done now.
Kind Regards, Mark.
Good news! Now go have fun with that thing!
