Is there ANY documentation on using dxf’s anywhere?
I have tried looking for docs or other information on DXF file import and export. I see nothing in the Software Documentation, I have tried manually expanding all the catagories.
Searching the forums there is a lot of hit-or-mis information about dxf files, mostly anecdotal, and mostly from trial and error. I have low confidence in what I am seeing.
Frankly, I expected Lightburn to be mature in dxf file import/export as its pretty much a univesal standard amoungst CAD/CAM platforms. I expected some basic information on what is or is not possible in the software, the limitations and recommended best practices.
The issues I am encountering is simple things like-
- Coordiantes 0,0 is maintained on file import.
- Layers/color managment to be better. Like objects on a layer named C00 with the color of black all stays on that layer
- Text as imported being altered in position and/or fonts.
- Items in blocks not get imported.
- spline & bsplines not getting imported or correctly.
- groupings being honored.
For what its worth, I am using 1.4.05. I have been an AutoCAD user for longer than I care to admit, and I am confident in my fluency for dxf use in CAD/CAM.
