I am using the udp interface to load an svg file into lightburn. When loading it manually (ctrl+i), it’s important to hold shift to use the coordinate system as defined in the svg (Position of imported files).
Do I get the same position when I use the udp-Interface with FORCELOAD as if I had had imported it with shift pressed? The svg was always positioned with the svg-frame, but I’d like to know if I can rely on it.
