Where to connect wires
I have just brought a new DLC32 V2.1 and a new laser module. The problem is my laser module came with a 2 connection wire to a 3 connection lead can you help please.
Can you take a picture of the cable again? Or draw the lines on a paper?
To me it looks like there is a separate power cable integrated. The laser module usually have VCC-GND-S on their connector. The S must be connected with the S pin of the board, the power lines need to be connected to one of the power ports of the board. Be aware that you have to power the board with the same voltage as the laser head requires. More information can be found here: Mainboard Replacement - Diode Laser Wiki
this ishow the wires are 2pin green/white 2pin red/black 3pin blue/yellow.
Other end 2pin red/ and 3pin yellow/green/blue and white
The wires consist of a 2 pin green/white, 2 pin black/red 3 pin blue/yellow. The other end is amale 2 pin black/red and 3 pin yellow/green/blue and white.
The white and yellow use the same pin, right?
Then just plug the 3-pin blue / white+yellow / green on into the laser. The green / white should go into the signal port, the blue /yellow into the power port. Though I think you might need to change the pins within the connector.
Do you have some laser module specs you can share?
In my case, the module has a 3-pin input (power and signal for the laser) and then there are two other connectors already connected, one being the output for the laser and the other the output for the fan.
It’s a good idea to understand what it’s like in your module before I giving any other instructions.
@misken
Sorry for the correction but… I also sometimes have sleep problems. :wink:
The image you shared refers to MKS DLC V2. 1. According to the description, the board in question is the MKS DLC32 V2. 1 which will be this:
In this case, the laser module connects with 3 wires in the upper right corner where the first pin is the signal, the second the ground and the third the power/24 or 12vdc.
I leave a link to other queries that may be useful:
Oh, I’m sorry, it was too late yesterday :slight_smile: The page I linked also includes all documentation for the DLC32 as well. This is the correct picture then:
When you have so much information to share, it’s natural to exchange information for identical items. :wink: :+1:
I was going to come back here and find the new layout you posted. I have the same board as @Kuth posted.
The pwm output is rather simple, as I’m sure @misken knows… It goes through a voltage translator, that’s the SN7400 type chip changing the signal from 3.3v of the native cpu to a 5v TTL level.
You straight 5v TTL signal is available out of TTL marked connector they have. The connector is called TTL, not the J18 like the internal schematics.
If you have an older led module that only needs it’s power switched on/off then use the spindle output which connect it to 12v and the dlc32 completes the ground via Q1.
BTW - where did you get the other board layout?
:grinning_cat:
