I had this made on Fiverr and the guy used AutoCAD to make it. I have always had issues importing svg files into lightburn that’s made in AC. So we been using the dxf format which seem ok. Until now.Can someone tell me why I have no engraving or nodes available.
I cut this out yesterday and it did fair but needed some revisions. It was doing the same yesterday. I only have the line no Fill. Can someone help?
I merged your double post below. Please do not post the same question in multiple places. One may think this up’s their odds of getting a faster response. Not so. It generates more work than should be required.
I had this created in Fiverr and when I import it I cant edit like others. Everything is in hundreds of different segments. The guy used AutoCAD or solidweorks to build it. I’m only using LB. Can anybody offer ideas why this happens or what I can do to fix it,. I only have the line look in LB no Fill. Nothing changes when Itry
The guy that’s created this keeps saying its right but I cvan’t do anything with it.,
Normally you would never need this setting. It can actually cause odd behaviors at times. I personally would leave it at 0 and repair the shapes using the other techniques listed here including what @Rick has documented. That way you know what you’re dealing with.
