I am new to Laser Engraving. I just purchased an Ortur engraver. I would like to order a camera, but need your help. Here is my situation. I would like to also purchase Ortur’s Enclosure. The only problem is that it is only 12.3" tall. The platform is 400mm square, but I will probably just be engraving small images, so I may only use 1/3rd of that space. I noticed on this page > Using a Camera - LightBurn Software Documentation
Lightburn shows a table of Camera selections.
which hopefully I uploaded correctly. It appears that the only choice is the 5mp-160 which only needs 8.75".
Any thoughts? is there a problem with such a wide angle lens?
Thank you for your suggestions,
Andy
Enter your information where it says ‘Machine Size’ to see the choices recommended for that setup.
I also suggest you search this forum ( upper-right at the top of each page) for “Ortur Camera Setup” to find many additional posts covering this topic in detail.
Thanks for the info, but at this point in my getting into laser engraving, I just want to make sure that a 12” high enclosure is not too short to work with your cameras.
I just received the engraver today and I want to be very cautious by getting an enclosure before operating the laser.
Once I have the engraver set up. I will purchase your software and will use the software, as you have indicated, to inform me which camera to purchase.
Si the question comes down to whether or not the 12” tall enclosure will work with your cameras. It did appear from the sample chart that it would work with 160 degree lens. I just thought it would be best to double check before buying the Ortur enclosure.
I see 2 options that would work within a 12" range.
The location of mounting is the key, so does this enclosure have a lid? Provide a picture or link to the enclosure design you are considering, and we can offer a bit more direct feedback.
Hi Rick,
Thank you so much for your help. I am attaching 4 images - front view with lid open, top view with an arrow where I expect the camera would be located (on the inside, of course!) a diagram that appears to show that the center (right behind the hinge) and another diagram showing the top view. As you will see, there appears to be some hole, but I would think I could go over it or next to it. I’m not sure what that circle representss.
While I think your assumption seems reasonable, I can not confirm Ortur’s intent here, best to ask them. I would also ask these nice folks if they have a camera recommendation to best fit that enclosure.
Additionally, I might suggest waiting to have the enclosure, so you can choose the best mounting location for your needs and measure that distance yourself.
Hi Rick,
Excellent suggestion on asking Ortur about a camera recommendation, but after doing my research I prefer your software, and therefore it makes sense to have your camera. But I will ask them anyway to see what they say. But after seeing these images and my assumption, can you please tell me which camera/lens or cameras you believe would work with this 12 inch high enclosure. I believe I have to first get the enclosure before I can choose the best mounting and camera setup. Otherwise I have nothing to measure.
Thank you,
Andy
