I’m looking to some new laser project,
close loop servo-, or close loop stepper motors, 24v-36v system. (Nema 23?) Each motor comes with a driver board, but the problem is the main board;
I can’t choose the motherboard for two motors, there is a place for limit switches (and what ever it maybe requires), is grbl and Light burn compatible.
Could anyone help me find parts to my project…
(money is not the problem number one.)
Yes, it depends on your plans. You can just select the bare mainboard, that’s enough. If you plan to use standard steppers, you can select it with TMC drivers or similar. You can also add a display. But you don’t need all this.
Yes, there is a firmware already on the board that runs ok. I recommend switching to FluidNC firmware, but that’s a later step maybe.
I do know some of the hardware, but soft, or firmwares nothing…
Is there anywhere MKS DLC32- board, ready to updated better version, fluidNC ?
I don’t need any screen, i have Lightburn.
You can update this board at any time. But if you don’t want to deal with a new firmware and its configuration, just stick with the firmware that’s delivered with the board. It’s fine for “just use it”.
Yes, you can. But I’d choose the DLC32 without the Max. The latter is quite new and therefore there is not much experience / support available. The Max looks quite promising, but it’s too new to say it for certain. But technically, yes. Both boards can drive steppers with step/dir configuration.
Can you explain the difference between the two types of displays? Mine plugs directly into the board, so what’s the difference?
I never checked the OMTech to see what it’s speed limit was, but the max is obviously quicker.
I don’t know how you’d use an interface to the control board as an e-stop, axes limits, coolant failure and maybe a cover protection maybe as a run error but surely not an e-stop.
In my opinion the max is just more versatile in usage. I don’t think you will really ever reach those speeds / better speeds with common setups. But you can now drive an additional axis and have connections for more sensors, it also supports higher-power laser modules.
I collected some information about it here: MKS DLC32 Max - Diodenlaser Blog (but it’s only in German at the moment). I have the board here, but without the display. It was out of stock around Christmas, as I bought it. But since the displays only work with MKS firmware and I usually tend to use FluidNC, the display was not interesting anyhow.
I know But I started the Blog as side project and it’s already much work to have the wiki in dual language, so I didn’t want to start it there as well…
But Google Translate can help: MKS DLC32 Max - Diodenlaser Blog
This board comes with FluifNC, does it work properly in lightburn,
Some says, that there is some problems using FluidNC, or does they fixed the problem(s)?
Is ther a better software that works in Lightburn?
What is the point to get that tiny display, i don’t get it.
I have my computer, 42" display! Why would I buy one?
The baseline is, that it works as long as the firmware on the board talks one of the dialects that LB supports. The most popular one is grbl, and the original MKS firmware as well as FluidNC both use that protocol. So there is no difference in usage, it’s just a difference in configuration and flexibility on the board.
I’ve been hoping to understand more about how those machines work. I notice that I understand a little more again, thanks for the clear answers! Maybe now I’ll dare to move forward with planning my project…
