Which is better, offset fill or flood fill?
I have a large lazy susan to make for a friend. The lazy susan will be 27" in diameter with the graphic 23" wide x 7 3/4" tall. Both burns are around 1.5 hours vs. 2.5 hours for conventional fill. Which process do you think will be the better approach? The wood will be maple so it’ll be very light to begin with and will have good contrast.
Thanks in advance.
Flood fill for sure.
Flood Fill divides a large design into regional islands/clusters, finishing one section before jumping to the next, eliminating the whitespace scanning of a regular engraving.
Offset Fill is more for engraving concentric shapes that follow an object’s outline from the outside-in or inside-out, like frames, borders, and hollow shapes.
You can also check the preview window for either option and compare the estimated job lengths that way.
Docs links:
Offset fill is faster (but not always!), but it can leave a visible pattern in the burn. For a quality project, use Fill or Flood Fill.
Thanks to you, Mikey, and Joe D above. Flood Fill it shall be.
