Which setting parameters for acrylic Sculpfun S6 Pro
Hello,
I have the Sculpfun S6 Pro and I’m a total beginner.
I was looking for the best settingsto cut Acrylic, mine is 3mm thick and I had no problems with cutting wood but any settings wont work with the acrylic :frowning: The last setting I tried was speed: 300, Max Power 90% and min 72.5%
any reccomandations?
If you are trying to cut clear acrylic, forget it…
Might have a chance with a colored verity.
Frequency of the beam from an LED laser (visible light) is different from a co2 laser (infrared).
The material has to absorb the energy for the beam to ‘damage’ the material. If the light passes through the material, it can’t damage it.
Good luck
