Good day, I need assistance please.
I am busy with a project and in the middle of the project my cuter just stops.
Here is the log it gives me:
Waiting for connection…
Project loaded in 11 milliseconds
Rotary setting update successful
Port failed to open - already in use?
\x1B[0;32mI (1336) serial: Line state changed! dtr:0, rst:0\x1B[0m
\x1B[0;32mI (1544) serial: Line state changed! dtr:0, rst:0\x1B[0m
[VER:CV-30.V3.0.24.20221012]
\x1B[0;32mI (2505) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 \x1B[0m
\x1B[0;31mE (2528) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).\x1B[0m
\x1B[0;32mI (2529) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 \x1B[0m
\x1B[0;31mE (2531) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.\x1B[0m
\x1B[0;31mE (2532) sdmmcfs: TF mount failed
\x1B[0m
\x1B[0;32mI (2533) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 \x1B[0m
\x1B[0;32mI (2534) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 \x1B[0m
\x1B[0;32mI (2535) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 \x1B[0m
[MSG:Axis count 2]
\x1B[0;31mE (2645) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2647) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2648) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2650) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
\x1B[0;31mE (2653) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2655) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2656) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2658) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
Grbl 1.3a [‘$’ for help]
\x1B[0;32mI (2836) serial: Line state changed! dtr:0, rst:1\x1B[0m
ok
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Homing
\x1B[0;31mE (3778) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (3780) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
<Home|MPos:-298.850,-298.850,0.000|FS:6364,0|Pn:X>
\x1B[0;31mE (8431) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (8432) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (8434) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (8435) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
ok
ok
ok
ok
ok
ok
ok
<Idle|MPos:3.000,3.000,0.000|FS:0,0>
Starting stream
Layer C03
Connection lost
Stream completed in 7:55
\x1B[0;32mI (499738) serial: Line state changed! dtr:0, rst:1\x1B[0m
\x1B[0;32mI (499774) serial: Line state changed! dtr:0, rst:0\x1B[0m
\x1B[0;32mI (501086) serial: Line state changed! dtr:0, rst:1\x1B[0m
\x1B[0;32mI (1334) serial: Line state changed! dtr:0, rst:0\x1B[0m
\x1B[0;32mI (1442) serial: Line state changed! dtr:0, rst:0\x1B[0m
\x1B[0m
[MSG:Axis count 2]
\x1B[0;31mE (2649) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2654) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (2657) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;32mI (2744) serial: Line state changed! dtr:0, rst:1\x1B[0m
ok
ok
Homing
[TLO:0.000]
ok
\x1B[0;31mE (3725) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (3726) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
<Home|MPos:-87.825,-87.825,0.000|FS:6364,0|Pn:Y|Ov:100,100,100|A:S>
ok
ok
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:03
<Idle|MPos:3.000,303.000,0.000|FS:0,0>
\x1B[0;31mE (70587) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
\x1B[0;31mE (70589) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first\x1B[0m
<Home|MPos:-289.788,-289.788,0.000|FS:6364,0|Pn:X>
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
Stream completed in 0:04
<Idle|MPos:42.463,21.737,0.000|FS:0,0|Ov:100,100,100|A:S>
ok
<Idle|MPos:42.463,21.737,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:42.463,21.737,0.000|FS:0,0>
ok
Starting stream
Starting stream
Layer C03
Connection lost
Stream completed in 9:26
\x1B[0;32mI (690806) serial: Line state changed! dtr:0, rst:1\x1B[0m
\x1B[0;32mI (690835) serial: Line state changed! dtr:0, rst:0\x1B[0m
\x1B[0;32mI (692141) serial: Line state changed! dtr:0, rst:1\x1B[0m
Please help
I’ve still got 23 pens to engrave before Saterday.Good day, I need assistance please.
\x1B[0m
[MSG:Axis count 2]
ok
ok
[TLO:0.000]
ok
Homing
ok
ok
ok
ok
ok
ok
ok
Starting stream
Layer C03
Connection lost
\x1B[0m
[MSG:Axis count 2]
ok
ok
Homing
[TLO:0.000]
ok
ok
ok
ok
Starting stream
[MSG:Pgm End]
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
ok
ok
ok
Starting stream
Starting stream
Layer C03
Connection lost
Please help
