Who else has an XTool S1?
How common is this laser?
Frankly, I’m upset that the problems I reported with my S1 were not resolved nor are they acknowledged as ‘known issues’ with the current 2.2 release. But if I’m the only one, then I could understand Lightburn not treating this as a priority.
I have an xTool S1 as well. I just updated to LB ver. 2.2 and I’m also having issues. I’m sure it’s something very simple, just not sure what. When I try to engrave the laser doesn’t fire and I get a pop up that says ALARM. In the Console the script says xTool: user started script line 1 dropped - not g-code this machine can run.
What I’ve found is that if you press “Start” a second time, the laser will fire. It seems every odd time it fails (i.e. “Start” - fail, “Start” - works, “Start” - fail, “Start” - works. That’s as far as I’ve tested. :slightly_smiling_face: )
The ‘not g-code this machine can run’ is a separate issue that is fixed by a change to the LBDEV file, as mentioned in an earlier thread. (Could someone post that link again, please?)
We are all victims. One Laser sucks too.
We just added a second S1 to the fleet so there’s some more eyes on this oddball.
The hard part is that while it is a fantastic machine, it breaks every single paradigm xTool has set with their other machines and basically needs to be treated like an entirely different platform.
I sent Lightburn Support an e-mail this morning and they replied. They told me to remove the S1 profile and then add it back in, which I did and it worked perfectly. I had to import the .lbdev file that I used to originally set up my S1 in Lightburn. Everything seems to be working just fine now. Reach out if you need any assistance, always glad to help!
Please walk me through what you did. I tried the obvious approach suggested by the instructions: Plugged in the laser, launched Lightburn, went to “Devices” and clicked on that. Then clicked on “Find my Laser” - and it launches the “discovery wizard” rather than the list that is showed in the “Xtool” page. (xTool - LightBurn User Guide)
The ‘LBDEV’ file I have on my computer is “XTOOL_S1_V2.lbdev,” that file is dated (probably download date) of Sept 11, 26. Is that the one you used?
This really should not be so damn hard! If the tech support people know how to do this, they should update that ‘XTool’ page. I’m really frustrated at this point.
In Lightburn (LB) go to devices. If your S1 is listed highlight it and select Remove. You should have no devices listed. I used the .lbdev file that I had on my computer from last year when I bought the S1. In the devices window select Import then find that .lbdev file and select open. Once you do that the S1 should show up in your Devices list and you should be good to go. Once I was all set I noticed that my engravings weren’t starting where they should. In LB if you go to Laser Tools (top of screen) then Device Settings turn Enable Pointer Offset on. X-axis should be 0.00mm, y-axis is 26mm on my machine and the engraving starts right where I want it to.
If you need anything else you can e-mail me at hlwoodworks@yahoo.com
So the order should be (1) load the LBDEV file, and then (2) the laser should show up under Devices?
“So the order should be…”
Yes, when you go to import and find the .lbdev file on your computer select Open. Once that file is imported your S1 should show up in the Devices window
I loaded the LBDEV file, then connected the laser. Now Lightburn found the S1.
But here’s what happens: (1) whenever I open the lid, whether the laser is running or not, I get an error. (Others have reported that.) (2) The problem I’ve reported, that the first time I press “Start” generates an error but the second time works, is still there. (3) Plus the problem in the LBDEV I installed that generates “not g-code this machine can run” is there.
Now the reason why I wanted confirmation of the order of actions (install LBDEV and then plug in the laser) was that I found that counter-intuitive, both because that’s not close to what I saw in Lightburn’s Xtool instructions, and because Lightburn seems to be somewhat “promiscuous” about what it finds as a ‘laser’. I would have thought (naively, admittedly) that if it thinks my Bose headphones are a laser, that it would also find the device plugged into the laptop via USB without first getting the LBDEV file.
So to summarize: (1) The Lightburn XTool instructions page needs to be properly written to address the S1. That includes providing the corrected LBDEV file as a download from that page. And the instructions need to be clear that file has to be installed before connecting the laser. (2) the two known problems, ‘error because lid is opened even when laser not running’ and ‘need to press “Start” twice’ need to be acknowledged and addressed.
I don’t think your headphones use the CH340 driver.
I thought it was pretty bizarre, but apparently not completely unknown for Lightburn to pick up other things in ‘Devices’
Any USB identifying itself as running a “serial” interface could be a laser, so ya never know.
Tell LightBurn to ignore those earbuds:
Saw an article about fancy prototype augmented-reality glasses using direct laser projection onto your retinas. If it had a USB port with a GRBL interface, you’d want to suppress that laser so hard. :grin:
Well lightburn finds devices, it doesn’t know what they are. It is smart enough not to assume!
