Why am I getting fill?
Why am I getting shape filled when in lightburn looks ok?
Running lastest version of lightburn and I have an Atomstack X20 pro
What does preview show?
yeah, the preview is showing as burned. It is happening because I am leaving the pattern outside of the work area and when Lightburn cuts it out, it is getting confused. When I cut it using a rectangle leaving everything inside of the work area it works fine.
I’m surprised you’re able to do this at all, at least with Absolute Coords turned on. I assume you have “Enable ‘out of bounds’ warning” disabled in Device Settings in that case.
I have it on, but I was assuming that lightburn will handle it properly, as if I was cutting it with the working area size rectangle.
