Can you upload the PDF for this project. You can add the extension .TXT to the end of the PDF filename. When I looked at you SVG from before, it didn’t look right.
Regarding the “Live on Patrol”, Those are fun to watch
I want to measure the material thickness in the drawing and correct the drawing after that. That is, I measure the material in the drawing to 2.8mm and I will scale up the drawing by 7.143% in Lightburn’s percent field to get 3.0mm. (107,134) is entered)
It appears it is setup for 3mm
