Good evening John,
Started my laptop. then the D1 laser and connected to the laptop. Loaded the file created this afternoon. Ran a FRAME and proceeded normally. Everything works until pressing START. Showed that there is a possibility to run outside of the boundary. Clicked OK and the module moved to the first location, the laser fired once and stopped… Then click STOP as the remainder of the file continues to load. This halts the file. I can reconnect the D1 and run the frame without trouble. Press START again and does the same as described above. The is the counsel information from the beginning.
Waiting for connection…
�ok
ok
ok
ok
[XTool D1:ver 40.30.003.01 B9]
Project loaded in 393 milliseconds
ok
MPos:0.000000,0.000000,0.000000,0.000000
Starting stream
Stream completed in 0:00
[MSG:Pgm End]
ok
Starting stream
Layer C00
M8 N4
Guru Meditation Error: Core 1 panic’ed (IntegerDivideByZero). Exception was unhandled.
Core 1 register dump:
PC : 0x40085038 PS : 0x00060e31 A0 : 0x80085e66 A1 : 0x3ffc0090
A2 : 0x00002710 A3 : 0x00000000 A4 : 0x9999999a A5 : 0x40b99999
A6 : 0x3ffbac04 A7 : 0x3ffb844c A8 : 0x8008502f A9 : 0x3ffc0070
A10 : 0x3ffbac04 A11 : 0x00001999 A12 : 0x0000000d A13 : 0x00001999
A14 : 0x7ff00000 A15 : 0x7ff99999 SAR : 0x00000013 EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40085038 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008d7a4
ELF file SHA256: 0000000000000000
Backtrace: 0x40085038:0x3ffc0090 0x40085e63:0x3ffc00c0 0x40085efd:0x3ffc00e0 0x400866b9:0x3ffc0100 0x4008d019:0x3ffc0120 0x40081889:0x3ffb1f70 0x400d2c32:0x3ffb1f90 0x400e48e5:0x3ffb1fb0 0x400909e6:0x3ffb1fd0
Rebooting…
f ~ �f~��
Job halted
Stream completed in 0:16
ok
Thank you for your help. Trying to complete Father’s Day engravings.
Terry Jones
