Why doesn’t lightburn support cdr files, causing me to mess with it for half a day? What files does lightburn support?
A full list of the supported formats can be found here: Basic Usage: The Essentials - LightBurn Software Documentation
There is a Corel plugin under Help > CorelDraw Macro Setup, in LightBurn. - see here for some context: CDR file support · LightBurn
And older, but still relevant context here: Import cdr files · LightBurn
Not obvious as CorelDraw format is binary and proprietary, hard to reverse engineer.
I download, from time to time, some CDR files from template sites, and I import them successfully in Inkscape. It will allow to save them to SVG, then to import in LB.
I have Very good luck with the website
you may wish to give it a try
As PhiLho wrote I D/Load into Inkscape and from there Cut/Copy then paste into LB…no problem…
