Why RUIDA doesn't light the laser below 10mm/s (80W)
What is the minimum of the layer set to?
Most likely the start speed in the Ruida is set to 10mm/s.
Anytime you are at or below the start speed, it will produce minimum power, as set within the layer. From my time with these, it works like this… Red is the power sent by the Ruida.
This is changed via File → Machine Settings → Start speed.
Good luck
