When i write a text in example in width 112mm and hight 28mm in Lightburn,and start engrave on a plywood, the final result have size width112mm and hight 80mm. This happened after i have been using the roller for engraving bottles. Before i used the roller, it all came out correct. Anyone know what causes this?
Perhaps you still have the roller option turned on, even though you’re engraving a flat sheet of plywood?
Thanks. I found out. Had to deactivate roller and then everything is now ok. ![]()
