I’m trying to use my LM3 remotely with WiFi and have had to reprogram the WiFi connectivity because it would keep changing the IP. Well now it’s decided to stop working all together. After using the $WRS command I’m STUCK with the message:
[MSG:75:Info: WIFI STAT KEEP TRYING CONNECT]
I have tried rebooting my computer and the LM3 to no avail can someone explain to me what’s going on with my machine and why I can’t get a WiFi connection to it??
gilaraujo
(Gil Araújo)
May 26, 2024, 3:18pm
2
Is it possible the SSID changed
Do the setup again
$74=mywifissid
$75=mywifipassword
$WRS
it should then give you a new IP
Make also sure the antena is healthy
I’ve already tried setting up the SSID again. That’s the first thing I tried to no avail. No matter what I do if I type the command $WRS I’m takin to the same message. I’ve also already tried updating the firmware and I still have the same issue
[MSG:70:Info: WIFI AP STOPED]
[MSG:69:Info: WIFI AP READY]
[MSG:76:Info: WIFI STA DISCONNECTED]
[MSG:75:Info: WIFI STA KEEP TRYING CONNECT….]
gilaraujo
(Gil Araújo)
May 26, 2024, 4:19pm
5
Try resetting firmware first
$RST=*
press enter
Power off → power on
Retry the wifi steps
then when done,
Type in console
$i
Copy and paste all the output please
Nothing has changed I still get the same error
$I
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:211]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230417]
[SN:3DCD0AF61B78237E5ABF6B48077C1626]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:84:F7:03:E6:AF:B8]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
$0=5.0
$1=100
$2=0
$3=1
$4=7
$5=0
$7=0
$10=2047
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=1
$17=4
$18=0
$20=1
$21=0
$22=1
$23=7
$24=600.0
$25=800.0
$26=100
$27=1.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.0
$57=1800.0
$58=395.0
$59=6000.0
$60=0
$61=1
$62=0
$63=3
$64=0
$70=31
$73=3
$74=Goodraven
$75=********
$76=OLM3_AP_AFB8
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=20040.000
$111=20040.000
$112=600.000
$120=2000.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$140=600
$141=1000
$142=800
$150=16
$151=16
$152=16
$160=0.000
$161=0.000
$162=0.000
$180=20040.000
$181=14028.000
$182=600.000
$200=65.0
$201=50.0
$202=60.0
$210=100
$211=100
$212=100
$220=50.0
$221=60.0
$222=60.0
$270=115200
$271=115200
$272=115200
$300=OLM3_STA_AFB8
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$306=80
$307=81
$308=21
$310=OLM3_AP_AFB8
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$330=admin
$331=user
$332=255
$339=3
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$392=5.0
$393=3.0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=1.000
$610=0
$611=0
$612=1
$613=227505
$614=0
$615=api.ortur.cn
$616=0
$617=0
$622=111
gilaraujo
(Gil Araújo)
May 26, 2024, 4:33pm
8
it is being unable to connect to the network
Try to connect to the OLM3_AP_AFD8 with your phone to make sure the antena and the wifi itself is working
I tried going through compatibility mode only for it to say I’m not connected to the correct machine hotspot even tho I’m connected to OLM3_AP_AFB8
gilaraujo
(Gil Araújo)
May 26, 2024, 5:19pm
10
When connected to the AP mode, 192.168.5.1 should get you into the WebUI
Do you get an error?
Remember on your phone you must disable mobile data and wifi roaming or it will automatically try to connect to the next wifi with internet
system
(system)
Closed
June 25, 2024, 5:20pm
11
