Will not connect to lightburn
Lightburn will not detect my Monport 40W CO2 Pro . Had the 40W reg unit and worked fine. Switched to the same machine, only the Pro. Changed USB cable, updated lightburn, with no luck. Any help would be so apreciated,
You might need to select a different serial port see:
I was wondering about that because when I select chose its own port, it still doesn’t find it. Then I took my 2nd laptop that has a copy of lightburn on it, but never was connected to anything and went to find my laser and it found it ? So I definitely no it’s not the machine. So I’m going to uninstall light burn off that laptop and try reinstalling it and see if it detects it. Thanks for your response I appreciate it.
Figured it out, had to uninstall lightburn and reinstall. 3 hours later after all the troubleshooting LOL. At least I got it thank goodness for that.
