Will only Etch for 6 or so seconds then stops
so i was able to do around 12 etches. Now when i try to etch , it will run for 6 sec then stop and i get these errors :
Starting stream
Stream completed in 0:00
Starting stream
Starting stream
error:25
On or near line 150:
Stream completed in 0:06
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
error:25
Stream completed in 0:11
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
Starting stream
error:25
On or near line 155:
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
Stream completed in 0:03
ALARM:3
ok
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Starting stream
Starting stream
Starting stream
error:25
On or near line 37:
Stream completed in 0:04
ok
error:2
ok
ok
ok
ok
ok
ok
ok
ok
ok
How was this file generated? Please save the gcode and post that file here for review?
Here is a list of the error that can be returned and their meaning: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Interface#grbl-response-messages
You have a communication issue of some kind, corrupting the file that LightBurn is sending to the controller. I would check to make sure that your USB cable is securely connected, and not traveling close to high-power wires like the ones going to the stepper motors.
