Window size of Cut Settings Editor
Has anyone experienced an issue with the Cut Settings Editor window cutting off the bottom of the window so settings can be saved as default etc.? I have one computer that is fine and the entire screen shows up, while another cuts off the bottom. Pulling out hair here!
Follow the advice in the duplicate post:
Correct, I have done some research and it seems to be an issue with windows 11?
