I updated to Windows 10 20H2 and got the following message (same with several other programs). I then went back and uninstalled the update to where I was this morning, ran a suggested Microsoft C++ update (almost all the messages are “bad image”. Lightburn seems to run after I close out the messages (usually 2).
This won’t help you much, but my system is also update to 20H2, no issues with any software including LB. Makes me wonder if something failed during the update.
I’ve queried Microsoft Surface Support. I might just try to run the upgrade again, but will see what I hear first. Thanks for letting me know that you don’t have a problem with the upgrade. You may be right, because I get similar errors on other programs.
If you search you will see that you need to uninstall Lightburn and reinstall.
