With LightBurn I do not have the full power of the laser
Are there people here who operate the Ender-3 S1Pro with Laser Module?
In my opinion the Creality software very limited, so I tryed the software LightBurn. However, I have noticed that the laser no longer lasers at 100% power with LightBurn. But I have set the power to 100%.
I also noticed that the gcode is different (value LightBurn “255” instead of CrealityPrint “98”).
Does anyone also use LightBurn and has a solution or even a profile for me?
The printer is not connected. I laser via the gcode via SD card.
:::::Example LightBurn:
; LightBurn 1.2.03
; Marlin device profile, absolute coords
; Bounds: X64.66 Y80.31 to X154.69 Y131.71
G21
G90
; Image @ 1000 mm/min, 100% power
M8
M05
G0 X66.858 Y80.313 F0
; Layer C00 Pass 1 of 2
G91
G1 X0.416 F1000
M03 S255 <<<<- S255 means 100% right?
G1 X0.2
M05
:::::Example CrealityPrint:
;Header Start
;estimated_time(s): 1433.863
;MAXX: 164.56
;MAXY: 132.22
;MINX: 55.33
;MINY: 80.56
;Header End
G92 X0 Y0 Z0
G90
G0 F3000
G1 F1500
M3 I
G0X55.333Y80.555
G0X57.333
G1X57.444S98 <<<<- S98 means 100%
G0X67.333
G1X67.555S999
G0X77.444
Did you setup lightburn/machine to the same settings?
Double check the installation instructions for Lightburn grbl setup.
This is usually due to the incorrect $30, $31 and $32 and the associated ‘S-value max’ in the device settings…
Good luck
Got the solution. Have now increased the S-value max from 255 to 1000 and I now have 100% power.
Great…
If that’s the solution, mark the thread ‘solved’…
Take care … have fun
