Galvo CO2 with rotary connected, if I have a design on the screen with rotary enabled and click start it brings up the rotary screen and starts the framing. If I design highlighted and I want to move the design with arrow keys to center on material I am lasering it won’t allow me to move the image. I need to close out rotary window (framing stops) to move image on screen
Correct, and as designed.
You can use the normal framing window (F2) to adjust the placement while framing, but it won’t frame “around” the rotary.
I just typically click frame with image highlighted and use arrow keys to adjust placement but with rotary enabled and click frame it won’t move image on screen with arrow keys. your saying click f2 rather than clicking frame?
That’s not what you said in your initial post - You said you click Start:
So are you clicking the Start button, or are you clicking the Frame button? The behavior is different.
Click Frame, adjust image with arrow keys if needed, click start from that screen brings up rotary screen with frame as an option, click it to double check image, see something want to change, try moving with arrows won’t allow
Ok, that’s as designed - The rotary window does not allow moving the job. Only the standard flat framing allows you to move the work with the arrows.
ok Thanks, Maybe something for future updates? its nice to be able to move it while your viewing the framing instead of guessing if you want to tweak something with rotary window open thanks
