I am using a Wizmaker L1 36W. When I first started using it 6 months ago it worked GREAT. 2 months ago when starting the machine it would go strait to home and lock up. The following are the error codes I am getting:
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 1:
Stream completed in 0:00
<Alarm|MPos:0.0000,0.0000,0.0000|FS:0.0,0|Pn:XY|WCO:0.0000,0.0000,0.0000>
ALARM:8
Homing fail. Cycle failed to clear limit switch when pulling off. Try increasing pull-off setting or check wiring.
ok
Grbl 1.1h [‘$’ for help]
[MSG:Check limits]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
