Word Distortion When Curving
Hello!
I’m trying to make a sword with an engraving on it in Arabic the sword happens to be curved so when I try to curve the phrase I want in Arabic it gets all distorted is there a fix for it?
123321
How are you curving the text?
If you are using the blue dot with selected text, then try toggling the “Distort” button in Text toolbar.
Some fonts just don’t play nice. If you’re getting passable results from the same technique while using other fonts, I’d suggest trying a different Arabic font or using a different technique, such as 3D Warp or converting the text to path and manually tweaking each character.
thank u so much! it worked appreciate u
