Reedt
(Tom Reed)
March 23, 2024, 8:00am
1
I am working on a project with very fine detail. I am making several passes, the software seems to want to cut each peice of the detail individually before moving on to the next detail. How can I tell Lightburn to pass over the entire piece with each pass?
cggorman
(Chris)
March 23, 2024, 8:15am
2
If normal optimization settings don’t help, consider using sub-layers to further refine.
And, as always, use preview playback mode to reduce scrap while tinkering with this type of thing
Hello to all.
Instead of making multi-pass cuts in intricate details where laser burns the same segment over and over again and that sometimes leads to material burn…
You can automatically make 1 pass cut plus 1 pass cut plus 1 pass cut and so on to let material cool a bit.
Using Lightburn sub-layers like in the enclosed example. It take a few seconds more but gives much better results.
At the end of the job start the job again (3 times in this case) or use cut job with 9 cloned sub-layers, …
Reedt
(Tom Reed)
March 23, 2024, 9:30am
3
Thanks Chris… Sub-Layers did the trick
