Working with layers
I have an array of grouped objects. For simplicity, three, but usually there are many more.
Each object consists of four layers
Each layer is a passage under a certain scan angle
When I start engraving my array, at first there is engraving on all objects of the first layer, then the second, and so on.
Is it possible to make it so that first the first object is engraved with all layers, then the second, and so on. Roughly speaking, all layers are engraved in the first object, then the engraving of the second object. Thank you.
You can change the Cut Optimisation Settings priority to ‘Order by Group’.
To do this, click on the ‘Order by Group’ button a couple of times to make sure that ‘Order by Group’ gets first priority, like this:
Yes, it helped. Thank you. But I made the settings like this:
