Working with text and layers
I’m not sure how to search for what I’m asking so I’ll just ask.
I have a text design that’s going on bamboo cutting boards. I’m using the font in Line but I want to change one word to Fill. I can’t figure out how to select just one word and change the layer so I can have it set to Fill.
I have four different versions of this design and if there’s a way to do this without re-typing them that would be great. When I originally typed the text I just used carriage returns between lines.
Will I have to type everything except the word I want to change to Fill and the then type the Fill word and justify?
I hope I explained what I’m trying to do so someone can come up with an answer.
Thanks for any help,
Ernie
is a grouped phrase? i think so, select all the word then click on “ungroup selection”. In this way you can select a letter at a time
Roberto,
I tried that but will give it another try in the morning. It’s late here.
Thank you for your reply,
Ernie
The Ungroup did not work. So, I finally converted the text to path and it let me change the layers. I did type each of the four lines of text individually so I only had to work with one line of text.
Now the alignment for horizontal and vertical centering does nothing. I can live with that and do that manually.
you are from? if you can/want tell it…
LightBurn does not provide this type of selection within a text string, not as you are thinking, but you can produce what you describe.
You will need to generate several “chunks” of text, the chunk for ‘Line’ work and a chunk for the ‘Fills’. You then arrange the chunks as required so it looks as you’d like.
Would that work for what you are after? :wink:
