Would like to Burn a layout/board for my Laser engraver
Hello,
Having really good luck with lightburn and Ortur laser. I would like to make a dedicated table for my laser and would like the “burn” the wood top to follow the same outline as what is seen on the software. When you look at the software main page, you see a graph paper setup to help you set your burnings. If this same outline was in the table top, the alignment would be easier. I am sure someone else has done this, hopefully in inches.
https://forum.lightburnsoftware.com/search?q=grid%2C%20%40rick
