Hello Lightburn team,
Unfortunately my english is bad and i have to use google translate.
I installed Lightburn and it works so far. I do have one problem: When starting Lightburn, the machine moves to the homing position. In the basic settings the Origin is on the bottom left. The homing position should therefore be X0 Y0 and Z0.
The work area is displayed correctly. The machine shows something else, see picture. I cannot move the machine with G commands because the direction is negative. How can I adjust that the X direction is positive. and the Y position must also be positive or, best of all, set to + 1000mm. Is that possible? If you need more information, please contact us.
Thank you for your information
Greetings Eduard
first Picture machine in Origin Position
second Picture the machine in Homing Position
IMG_20201129_105634|375x500 !
