Wrong speed k40
Hello guys,
My laser or lb is acting strange randomly. I have set 5 squares of 20mm sides each. Speed is 5 mm/s So it should cut in 4 or 5 minutes. In the preview, it shows 50 minutes, and when I press start you could not see the head move, even if it does.
Can you help? Thanks
Sure you are in mm/s, not mm/min.?
5 mm/min is 0.083mm/s…
Edit → Settings
Let me double check.that :-).
