Wtll inkscape work as lightburn
wtll inkscape work as lightburn. what I mean is, Can I use Inksape to design and then send to laser and do all the setting up for engraving & cutting
You can do that. You will need to change your DPI settings to the Inkscape default.
You can draw and construct in Inkscape but not control your laser with this program directly. The drawing must be exported to LB and all properties for laser processing determined in LightBurn.
